1987 Buick Grand National T-Tops
1G4GJ117XHP439802
The time has come to sell the Grand National. The Wife has been very sick & I just don’t have the money & time to work on it any more. I have only put about 50 miles on this car since I bought it last year. This car runs VERY strong I blew a head gasket on the drivers side & I replaced it with a Felpro 1000. The car ran great but the cheap head gasket is starting to leak. The cylinders are holding compression & plugs are dry. It’s leaking in the coolant passage. This is a very solid & rust free car. The paint is in great shape & the tops don’t leak. All & all the car is in great shape. I hide nothing. Back on 10/11/1994 the car was recovered from a theft. It had 22,746 miles on it. The Insurance company rebuilt the car. It has passed any & all inspections since. You can run it or I can give you a copy of the CarFax report. It has a “Rebuilt” title which is valid title that is transferable in all states with no problems. You must see this car to appreciate. No disappointments.
Stock Buick 3.8L SFI Turbo (40K mile GM crate engine)
Stock camshaft, lifters, and timing chain
High-volume high-pressure oil pump
Heads:
Stock port matched
1.77” 1.50” SS Manley valves
Crower 80lb valve springs
ARP Pro Head bolts
Intake:
Stock ported Intake
62mm throttle body
Induction system:
TE-51 turbo w/.63 PTE exhaust and polished compressor housing
Charged Air Systems V4 stretch stock location intercooler
High Boost Adjustable waste gate actuator
3" BGC chrome MAF pipe
LS1 3.5" MAF Sensor with Translator
9” K&N with 3.5" inlet air filter
K&N valve cover breathers
Chrome up-pipe with sneeze valve
Chrome turbo cover
ATR Cyclops air dam
Fuel system:
Walbro GSS 340m in tank fuel pump
Casper Electronics fuel pump hot wire
Accufab billet aluminum fuel pressure regulator
MSD 50lb fuel injectors
Ignition system:
Accel Coil
AC spark plugs gapped 0.035”
Exhaust system:
Stock ceramic-coated headers
Terry Houston 3” down pipe
3” test pipe with dump tube
ATR Stainless Steel 2 ½” dual exhaust
ATR 2 ½” aluminized Pit Bull Mufflers
Cooling system:
Stock cooling fan with resistor by-passed
160 thermostat
B&M transmission cooler
Transmission:
BRF TH200R-4
Stock D5 torque converter
Hardened stator
Stock clutches with extra clutch
B&M Transpak
Suspension:
Stock 8.5 w/3.42 gears rear end
Air bags in rear coils
ATR Pinion snubber
Poly front sway bar bushings and end links
Driveshaft Loop
Stock GN wheels
235/60/15 BFG radial T/A
Body:
Energy Suspension poly body bushings
GM Front frame braces
BGC Rear seat braces
Jay’s GN Front fender braces
Engine Management:
Stock ECM
BstC Boost Command in-car boost controller
Extender Chip
Tuning and monitoring equipment:
Scanmaster II scan tool
Mini tach
VDO 30lb boost gauge
VDO oil pressure gauge
VDO temperature gauge
VDO voltage gauge
$7000 obo. I live in Minooka, IL. 60447
Carl
1G4GJ117XHP439802
Heads:
Stock port matched
ARP Pro Head bolts
Intake:
Stock ported Intake
62mm throttle body
Induction system:
Chrome turbo cover
ATR Cyclops air dam
Fuel system:
Ignition system:
Accel Coil
Exhaust system:
Cooling system:
160 thermostat
Transmission:
BRF TH200R-4
Hardened stator
B&M Transpak
Suspension:
ATR Pinion snubber
Driveshaft Loop
Stock GN wheels
Body:
Engine Management:
Stock ECM
Extender Chip
Mini tach
VDO voltage gauge
Carl
