FS: 87 Grand National
rpoL98
SOLD, 3 Aug 2016
Oahu, $12K. 94K miles.
TurboTweak (TT) chip & 42# injectors, Walbro fuel pump, TA49 turbo (rebuilt by Turbo City), 3" BGC downpipe (stainless), RJC 4" cat-back stainless exhaust, Hotchkis rear boxed control arms, TA cast aluminum differential cover w/ pre-load screws, 10-bolt 8.5" rear w/ posi, 4 new BFG tires, factory digital dash, vacuum brakes conversion.
also:
ARP engine main cap studs, new Moog front coil springs, KYB Gas-a-Just shocks, Moog HD idler arm, new rear brake cylinders & shoes, stainless braided brake hoses frt & rr, ARP differential cap studs, pinion snubber, driveshaft loop, front frame braces, rear seat/trunk diagonal braces. Gbodyparts.com 15x8, 15x10 GN-repro aluminum wheels. McGard wheel locks, lug nuts. 275/50/15 rear BFG drag radials. engine oil pre-luber, Earl's trans cooler, powdercoated finned alum deep trans pan, Art Carr (original) shift kit, RJC "Biggie" oil filter, RJC rocker shaft braces (3 each side w/ ARP bolts), RJC PCV valve, Pontiac Turbo Trans-Am vacuum distribution block, welded & braced drivers' side exhaust header, Dynomax stainless intermediate muffler where the catalytic conv was. fuel pump "hot-wire" kit, Accu-Fab AFPR, new fuel tank level sending unit, new WIX fuel filter. Bosch Platinum spark plugs, new coil, MSD spark-plug wires, heated O2 sensor, K&N stock-style air filter, Kenne-Bell intercooler fan shroud. Apexi turbo timer, Scanmaster. Mobil 1 oil since new. Factory radio w/ Pioneer 2-way coax speakers. generic rear fiberglass bumper filler, SpoolFool front bumper fillers, custom-fit car cover. the seat upholstery is good, the front seat covers were installed years ago to preserve the GN-original material from wear & tear.
VDO gauges: vac/boost, volts, water temp, oil pressure.
2nd owner, car originally purchased from Schuman Carriage. car was repainted about 25yrs ago when contractor painting the tower at Hickam oversprayed a whole parking lot. trans was rebuilt by Kalakaua Trans back when they were still downtown. all papers current.
also have GM Service Manual, original chrome steel wheels, NIB GM power radio antenna. power antenna on car (it's 2nd one) stopped working long time ago, not worth fixing since they always crap out, sooner or later.
also posted in the for Marketplace, Cars for Sale section.
http://www.turbobuick.com/threads/fs-87-grand-national-hawaii.439096/#post-3652393
originally listed for $14K on April 4th.
dropped price to $12K July 7th. registration and safety check are renewed, May, March 2017 respectively.
sigh, probably next step is craigs list.
SOLD. 3 Aug 2016.
I'm not looking to buy another car (just grabbed a Miata for daily duty), but if you want to sell the wheels separately and put some cash back in your pocket... Let me know!
I'm in Ewa.
sorry, the aluminum ones stay with the car.
you wanna buy the car? just kidding. good luck, thanks for asking.
