fenderdump
- Jun 7, 2004
NEW Cotton's front mount $900.00
NEW Max Effort 8 position thumbwheel with red stripe chip $100
NEW deep sump 20 bolt oil pan and pickup $200.00
NEW hid kit. all wiring, ballasts, new H4 glass housings $500.00
NEW GM driver door $1,000.00
NEW GM passenger door $1,000.00
NEW GM driver fender $500.00
NEW GM passenger fender $500.00
NEW GM radiator support $350.00
NEW rear Bilsteins $100.00
NEW MSD DIS 4 HO $350.00
NEW GM Delco 120 amp alternator $100.00
NEW Powermaster 200 amp alternator $250.00
NEW Accufab FPR $100.00
NEW Mark Williams 10 bolt 8.5 yolk $135.00
NEW ARP 12pt head bolts $50.00
NEW Lexan winsheild.has a corner chipped $200.00
NEW Crankshaft specialties 3.590 crank $1600.00
NEW Moser 28 spline axles $215.00
NEW custom made stainless steel fuel rail needs finishing $130.00
NEW airlift air bags $60.00
NEW AVC GNX dash. comes with wiring, lenses and no gauges $400.00
Used ported intake with plenum $350.00
Used billet top FPR $85.00
Used short block needs rebulld $500.00
used off center aluminum rods $300.00
used Moser 30 spline axles with c clip eliminators. one stud needs to be replaced $150.00
used ARP rod bolts $50.00
used GNX fuel gage $50.00
used GNX water temp $50.00
used Airlift airbag/one new $40.00 for both
used .30 over block with girdle. freshly done $1,200.00
used fuel rail $50.00
used starter $40.00
used valve covers. each side has oil fill so you can use breathers on each valve cover. they look stock. $60.00 for the pair
used BMS "Buick" valve covers $150.00
used MAF $50.00
96champs@bellsouth.net
used starter $40.00
used MAF $50.00
