FS: PSM Cold Air Intake Setup
Venus
I've got a Performance Systems Mfg. Cold air Intake kit that came off of my 86 GN. Everything is in really good condition and there is nothing wrong with the kit. Everything is included to mount this to a stock turbo, and it uses the stock air temp sensor, and I even think it would work with a aftermarket turbo depending on the turbos inlet size but im not 100% sure on that. This kits uses all existing mounts and bolts on your car so no drilling is required to use this kit. Reason I am selling is because I put the stock air cleaner assembly back on my car and no longer need this. I am located in Ohio and will ship to the lower 48 only via UPS ground. The picture of the kit installed on a car is not a picture of it installed on my car but on someone else' s car FYI. I am asking $200 shipped to the lower 48.
Thanks,
B-
