RichieRocket
- Mar 21, 2022
I am currently running two 240s with two Hotwire kits. As I move to larger injectors, I want to make sure they eat well. Nothing will blow your car up faster than leaning it out on the big end of a 1/4 pass, except maybe 50#s of boost . So before Bowling Green in May I decided I will install this, I will wait on the 133# 1400cc injectors until I get some help tuning the FAST xfi. I may be able to do that after a couple test hits on the old Precision 96# injectors on May 10th and 11th. Here are my new pumps and injectors. I run -8 feed and -6 return PTFE. Lines. Dual In-tank System Turbo Buick G7X 510LPH QD E100 (DPFS-G7510EQ): Dual Pump Systems (Complete) | Racetronix
GB SEP / Bosch 60:14:14 1400cc/min, 133lb/hr@43PSI Injectors Wondering if there are some running these pumps or even a very similar setup and the verdict as an overall Consensus of this fueling strategy.
