As some of you may know, standard SAE 30R9 fuel injection hose is not rated for submersion in gasoline. The outer jacket is said to swell and eventually the hose will fail.
eg, see:
http://www.gates.com/europe/brochure.cfm?brochure=3014&location_id=2958
or
http://www.acdelcotechconnect.com/pdf/tsb/tsb_fuel_line.pdf#search="acdelco fuel hose filetype:pdf"
SAE 30R10 hose is rate for submersion. The application is the short section of 3/8 hose connecting the output of an aftermarket fuel pump to the fuel sender's 3/8" metal output tube.
I have searched and found the correct part # for this 3/8 hose:
Gates Hose # 27097 .
After calling 5 Gates distributors, I found one who knew what I was talking about, and is ordering the hose.
It comes in 1 ft lengths, costs about $13. Pricey, but it seeems to be the right hose to use inside the gas tank.
eg, see:
or
