fuel line
buickGN3:16
who can tell me where to order the fuel line that comes out of the frame at the bottom on the drivers side & goes behind all that crap to the passenger side fuel rail? Or should i use -4an hose & fittings? I dont want to pull all the accessories off again to get the steel bend fuel line behind it all. found it shoved in the frame & kinked after i finally got all of the accessories back on the front of the motor. Whos got advice here & whats the best way?
Nos4gn probably has them
Call Classic tube ask to speak to Tim. He usually answers the phone when you call. They can sell you that line individually. You can also buy two 3/8 fuel line ends Dorman makes them. Buy a straight line and Bend the tube yourself.
i ended up with -6an braided hose & the fittings i need for each end. Thanks for the info guys.. The -6 is a little bigger than the 1/4" stock steel line so i hope it dosent affect the volume or the psi to the fuel rail
thats the return side so it cant affect the volume
the larger hose may get rid of some restriction that is there on the 1/4 steel return line
check and adjust your base pressure (line off pressure)
make sure the vac line to the regulator is sound (no leaks or kinks)
and ziptie the vac hose connections
Not sure where you came up with that being the return Paul, passenger side of the fuel rail, comes out of the frame, sounds like feed to me.
