Hi,
I run a tt chip with #60 inj and 255 walbro with hotwire. When pushing her hard (around 15# of boost) she was knocking per my scan master. I turned up the fuel pressure to 45psi (without vacuum) and knock is gone.
Does this make sense? The instructions and common wisdom is 43.5psi on fuel pressure.
Fyi- i have a blm stuck at 140 and o2 levels seem high (+850) sometimes. i think its preturbo leak, as when i ran smoke through 3 way spliter, smoke came out from under the turbo and my intake k&n filter.
