Flyin Brian
- Jun 18, 2011
My cowl mount fuel pressure gauge flutters +/- 4 psi at WOT. I have my base fuel pressure set at 44 psi and at 15 psi boost it flutters around 55 psi. It should be steady at 59ish. What could cause this??
I put a new filter in, the old one was fine. I checked the hot wiring to the fuel pump, it seems good. My stock lines are modified from the frame to the rail. -8 feed and -6 return. Saginaw fitting on the return has been cut off to allow the fuel pressure to be set low enough with the Deatschwerks pump. Saginaw fittings are still on the feed line at the filter and near the motor so I know I only really have about a 1/4" ID feed in spite of the -8 from the frame to the rail. It was that way when I bought it. At 5300 RPM in third my injector DC is at 85% with 15 psi boost and an AFR of around 11:1 as read on the gas scale. I figured the 80 lb injectors should get my motor to 20 psi boost (that is what the TT chip is burned for) and still keep the AFR down near 10:1 assuming I have enough fuel pump. I know I need a double pumper, better lines, and possibly to dual feed the rail eventually to run real boost but shouldn't the Deatschwerks pump be doing a little better than this? Or is my motor really moving that much air?? I have checked my gauge against other gauges and it checks out.
Thanks for any input.
