Fuel Pressure Gauge Install
JadeMonkeyStang
TRs on the Brain
I'm trying to get ahold of the pieces I need to install a rail mounted fuel pressure gauge. Caspers has the schrader T connector which I assume is all I would need, but it's $15 plus shipping. Does anyone know what size this piece is and if it is something I could perhaps find locally? Thanks in advance.
-Jade
You don't really "need" the T fitting. It just allows you to still have a schraeder valve as a test port.
If you unscrew the cap on the end of the fuel rail and use a valve stem/schraeder tool you can remove the stock schraeder insert and go ahead and screw on your guage.
Good Luck,
John
That "Tee" fitting is a refrigeration piece. Any refer and some good plumbing supply houses should have it. Its 1/4 SAE.
I'm never gonna finish this car:(
