Fuel pressure gauge sending unit location
1984 t-type
Murphy's Law
So I thought I had a solution that would allow me to run both my under-hood gauge and electronic sending unit both off of the fuel rail but it didn't work in the long run. Does anyone else have a way they are running both off a stock fuel rail ?
Thanks I will check that one out. Is that the right part number or just something similar ?
If I used the Casper’s adapter what size are those threads I would need to adapt it to this sensor. It’s 1/8 npt male.
Just went through this.
The end of the fuel rail is 4 AN. I had an aluminum adapter that allowed me to use both
my Kirban's Fuel pressure gauge
https://www.kirbanperformance.com/product/111/EFI+FUEL+PRESSURE+MECHANICAL+GAUGE+KIT+#6629.html
and an electronic pressure gauge (1/8 NPT) . That aluminum one split recently and started leaking. I found a stainless steel version here:
https://www.pegasusautoracing.com/productdetails.asp?RecID=28714
I have also inserted some stiff, heat resistant foam under the whole assembly to help with support and vibration.
