Hi, I did a search but I really didnt find what I needed. I had to replace my fuel system because the car sat for too many years with old fuel in it. so I replaced the entire fuel system.and had the rails cleaned. right now im just waiting on my regulator. so the stock one is still in. when I start the car it has a constant flow of pressure and I cant find any leaks but I can smell a very small gas oder. but as soon as I shut the engine off the pressure goes to zero right away. the only real changes I made was to the return line. I made the return 3/8 to match the feed.
so here is what I did
feed 3/8 alum hard line from the tank sender to the rail.
return 3/8 alum hard line from the rail to the tank.
all 6an fittings (even on the sender) no rubber hoses at all
aeromotive 10 inline filter
aeromotive stealth 340 pump
hotwire
fuel rail pressure gauge
the pressure is constant at 23 psi (only because I didnt get the regulator yet. waiting on ups) I know its too low. but my concern is why is the fuel pressure gone as soon as I shut the engine off?
what did I do wrong?
Is it because I used a 3/8 return line? is it too wide?
I thought using a wider return line would make my pump work a little easier.
any help would be awesome because I really dont know what im doing.
hotwire
