Fuel Pressure Hook Up to XFI
huntsg
TurboBuick.Com Supporter!
I'm sure it's here somewhere, but I searched and can't find it. I'm hooking up a fuel pressure sensor (got it from Julio 2 years ago and used it with my power logger until I switched to XFI) to my XFI. Can someone tell me where the signal wire goes and how the calibration needs to be done? Thanks.
It connects to XFI pin C12. If you're using a Caspers adaptor harness, this can be accessed through the EGR plug in the engine compartment. You will need to open up your black Caspers adaptor box and move the jumper from EGR to Fuel/Oil
Sent from my SM-G955U1 using Tapatalk
Thanks. I don't have the Caspers harness so I'm assuming I need to go straight to C12.
Sent from my iPhone using Tapatalk Pro
So if we have the egr adapter harness for GO and oil pressure do you still have to make switch? How old of a casper's box will this work on?
Yes. The switch has been in the adaptor for years
Hey......
Had to have mine fixed by Caspers ( left side ), but they no longer put that switch in there.
