Guys,
Here is the deal.
I have an 87Iroc-z camaro. I just did a 3.8/200r4 conversion. I did the wiring myself(yes, it was fun but wasn't too bad really).
The car fires right up, hold 43lbs fp at idle line ON. But when I get on it, my boost guage reports about 16psi and sometimes tries to climb higher(I left off of course).
The engine is a 70k mile motor, stock injectors, stock cam(new, old one had the classic #3 exhaust lobe gone), ported intake, and a 9inch K&N filter.
The turbo is stock, no shaft play and a stock waste gate, stock GN downpipe.
Now that you know about the car, here is the deal, the fuel pressure will go up to 60lbs if I feather the throttle but If I all out floor it the boost shoots up to about 16+psi on my mechanical autometer guage(I'm a little leary that this is under reported, since I can hear the car spooling and pulling before boost registers on the guage).
I have replaced the fuel pump recently(2 days ago) and put a new fuel filter on.
I have also done a homemade hotwire setup to the fuel pump(10guage power wire with a 30a relay).
I have switched vacumm ports from the FPR to various intake ports and that hasn't changed anything(figured, may it wasn't getting proper vacumm?). I do have an adjustable FPR also(have tried a stock one as well, same problems).
Now, the car does have vacumm brakes, I have simply ran the vacumm line over to a port on the intake for that, brakes seem to work fine.
The weird thing is, "sometimes" the fuel pressure will ride high and work as intended(60+ psi). It even did this before I did the hot wire setup.
I've come to the conclusion that there may be something in one of the fuel lines? Like a piece of rubber or something like that.. I don't know though.
Any ideas/help would be appriciated though.
Thanks,
Brendan
Here is the deal.
Thanks,
Brendan
