The Darkside
Heavy Metal Thunder
- May 25, 2001
I had the fuel regulator off recently due to replacing the head gasket & I noticed it leaking today... I took it off & it the o ring between the regulator & the fuel rail was damaged....I guess I must have pinched it when I put it back together. Anyways, I went to the auto parts store & bought a Felpro o ring kit that's designed for our fuel injectors(supposedly the same size as the regulator o rings)... Before installing it I put some Vasoline on the o ring & slowly & evenly tightened it up... It leaked even worse!!! I took it off & reinstalled it 3 more times & each tme it still dripped. Went back & bought a o ring kit that had several different sizes in it from the auto parts Help section... Installed one of those that looked like a perfect replacement & although it's not dripping now , it is still slightly seeping gas... Do I need to go get a GM o ring or what? I did notice that whenever I took the regulator off when replacing the head gasket that it came off kinda hard & felt like it was popped into place.... It doesn't feel that way when I put it on or take it off now.... Any suggestions?
The Darkside
The Darkside
