fuel pressure
hammer1918
Today i was goin to go cruise the gn around backed out of the garage got out to close my shop door gott back in the car and it wouldnt take throttle. Popped the hood 20 pounds fuel pressure then dropped to zero. Car dies let it sit for a minute started back up had 42#s them it dropped to 20#s then zero again. Tried it again a little later same thing. Do you think it pump,filter or relay. New to gn only had the car for three weeks. Thanks for any info.
Im new to these things too and know how frustrating it can be especially after you've only had it for weeks. Check to see if the fuel sender hose is leaking
The gas gauges on these cars don't work very well. LOL!
Throw a battery charger on and run the pump with the engine off. As pressure drops listen to the pump. If it's dying you will here it slow down and stop. If filter is clogged it will load up and sound like it's straining. If it's starving it will speed up.
HTH
RL
