fuel presure
copteaser
40 over pistons, 50 lbs injectors, 212-212 cam, ported heads TE-45 (a) turbo. what should the fuel pressure be?l
What chip are you using?
What is your boost pressure set at?
The most important thing is to tune for zero knock under wot. While o2 #'s aren't the best way to tune, they normally should read between 760-820mv at wot. Again, adjusting your fuel pressure to prevent detonation is the key. Your chip maker may be of more help on that note.
I'm not familiar with a turbo that size, so maybe someone who is will point you in the right direction. :)
