fuel problem..???
FatNasty231
i'm sure this is most likely my problem,but i wanted to hear someone elses input on it. my car is turning over good with no problem,but i'm not getting a reading on my fuel pressure gauge. i disconnected the fuel line that goes from the rail to the gauge,and when i turn the key on,i'm getting fuel. i can cycle my key on and off 10-15 times to load the rail up with fuel,and it will run for maybe a second or two. so i'm leaning toward my fuel pressure regulator took a dump on me. any ideas or suggestions would be appreciated. :confused:
Jump the pump test lead to the alt hot post, and see if the pump runs, and the pressure is up...
Alot of those fuel gauges are junk.Borrow a known good one.Have you driven the car at all?Your FPR could also be your problem,dont forget to check the hose to it. or weak fuel pump,clogging filter.Not many like to replace the fuel filters but you HAVE to with these cars.
