fuel pump 340 walbro
How fast do you want to run. The 307 is good for high 10's. I ran the 307 in the very low 11's no problem. If you are going to do all that work might as well put in a double pumper. Just a hint. Good Luck! :)
i have everything on there it runs fine but im thinking of getting a t62 or a t70 single bearing with 55lbs injectors, some of my buddys recommend i just get the 340. but if the 307 can handle it well ill give it a try.
