fuel pump block off bolts/studs
DCVING 6
Trying to get the fuel pump block off back on my timing cover with the cover already on the car... :rolleyes:
Does the stud to closest to the radiator or closer to the block?
Stock is two bolts. I would guess the stud was put there for the fuel lines clamp.
I thought it was a stud and nut that held the clamp? I guess that would tell me too, which one should the clamp go on?
Every 86/87 I have seen had two bolts and one had a clamp/bracket for the fuel lines
