fuel pump died today
I ordered the Aeromotive stealth 340. I'll review it and report back. The one that went out on me was only 2yrs old and there was no warning.
Tell us the one that failed at 2 years................................
TRE performance(TRE-340). It worked fine while it lasted and I didn't think my set-up was too extreme. lesson learned.
Look at Deatschwerks line of pumps
If you followed this advise you would not have to buy another fuel pump for at least 3 years with the DW warranty.
Aeromotive is a good product and I hope you get good service out of it. :)
Well said............................buy the best, only bitch once...........................
I won't be out of practice dropping this damn tank, that's for sure. I've heard good things; hopefully this Aeromotive pump will work out.
Thanks for the advice guys.
Good luck, double check all hose connections and wiring............. after a few installs / re- installs, we tend to get complacent ??
You'll be creating a new problem that will cost you more money if you use this pump. You'll need to replace the return line with a larger ID line.
Installed the pump and it's not running. If the Aeromotive polarities are reversed; does that mean the black wire is power and the red is ground?
Aeromotive=reversed polarity..got it. rewired, pump works, but no fuel pressure. Other than clogged filter or line, is there something that would kill fuel pressure?
On to regulator and filter; anyone else have this issue?
