fuel pump differences?
I'm pretty sure the armature motors are different for one thing. The 340 draws less current, I wouldnt consider a 307 for a TR. In fact I would suggest an xp, not that my opinion counts for much. HTH
Here's something I found on a quick search.....
"The GSS307M and GSS340M are the highest output in-tank pumps Walbro makes right now. Both supply the same volume 255L/Hr (67US Gal) @ 13.5VDC @ 3 Bar / 43.7PSI. The GSS340 model has a higher internal pressure setting for the safety bypass. The GSS340 pump is better suited for F.I. applications where line pressures will exceed 60psi."
Discussion
HTH
