gn86randy
No can......can
- Aug 1, 2004
I dropped the Tank and removed the pump. Then I plugged a hotwire and a ground wire to the adapter that came with the 340 just too see if the problem was the pump, It worked then I tested the hanger with the old pump I had taken out, worked fine then I put the 340 back in the tank and tried the hotwire and the ground wire test again this time NO luck it was DEAD, any ideas? thanks in advance for the assistance I will receive..........Randy
