My car has been sitting for about 5 to 6 years so the fuel system is dry. My have to run a little while.Thanks I will check this out and get back to you. I really appreciate your input
SignUp Now!My car has been sitting for about 5 to 6 years so the fuel system is dry. My have to run a little while.Thanks I will check this out and get back to you. I really appreciate your input
Did the test as you said I saw battery voltage on pin A for a few seconds great input sir. Now just to be sure if I’m getting voltage to the pump area. Going to put ECM back in it proper place. Plug relay back in jack car up and check pump connections while crankingMy car has been sitting for about 5 to 6 years so the fuel system is dry. My have to run a little while.
It’s quite but when I put the battery in the car for the first time and turned the key I heard the pump but nothing sense thenDid the test as you said I saw battery voltage on pin A for a few seconds great input sir. Now just to be sure if I’m getting voltage to the pump area. Going to put ECM back in it proper place. Plug relay back in jack car up and check pump connections while cranking
Hope you see this thanksPin A only gets power for a couple of seconds to prime the fuel rail after Key ON, until the car is making over 4psi. of oil pressure or actually running then it's continuous.
Takes abut 12 seconds to reset the ECM after key ON priming to get another reading.
Put a volt meter with a long lead to the relay so it's inside the car when the key is in the ON position to see if you get voltage for a couple of seconds, or put a gauge on the fuel rail tap to see if pressure builds after key ON test.
If you have a helper have them do a Key ON test in the car a few of seconds while you watch the meter if it's located at the relay location. Sometimes you can hear the pump run when key is put to the ON position not cranking.
The ECM/IGN fuse powers the relay through the ECM.
SalvageV6 made test leads up so I could see test light and yes got the light going in tank. Would to upgrade pump turbo tweak out of stock should I go summit?
Just want to keep the bugs off when get on itFuel requirements depend upon your goals for HP after mods.
For a mostly stock car this should work fine and he has the adjustable fuel reg. if needed, hot wire kit for the pump, and a new gas tank if needed etc.
I have no idea what Summitt sells for fuel pumps I support our vendors here when possible.
I can tell you they're short of parts, just like everyone else...Fuel requirements depend upon your goals for HP after mods.
Everything is tight right now so I’m going stick to the basic just a little mustard. The plan 60lbs injectors with good pump, 2800 stall converter, bigger turbo and inter cooler 3inch down pipe for startersI can tell you they're short of parts, just like everyone else...
Last week, a June 18 delivery for a Walbro 255.
Hey scooby my fuel pump should be here soon. I need Eric information so I can order his chip because I plan to install 69lbs injector. Trying to locate a scanmaster and regulator as wellIf you have Erics chip, then you have to set the fuel pressure via an AFPR. If you haven't got a TT chip from Eric, then I highly suggest you do. He has chip/injector combos on his site.
Where do I find this hot wire kit, and instructions for install?I can tell you they're short of parts, just like everyone else...
www.casperselectronics.com
Thanks for the updated information. I also saw another kit that increases voltage at WOT to 2.2 voltage.you can find one at the following location.
Fuel Pump Wiring Upgrade 1984/1987
Fuel Pump Wiring Upgrade 1984/1987Absolutely essential upgrade item for your turbo car! Increases fuel pump volume by 15% or more! By far the finest 12 gagewww.casperselectronics.com
What is the website for EricI'd be trying to order everything I could from Eric. I'm up here in Canada and he busted his ass getting everything to me as quick as possible.
Eric is known as Turbotweak and can be found here:What is the website for Eric
Thanks will look into it appreciate your help
