Donnel Childs
- Aug 17, 2013
Hi I was trying to get some help with my fuel pump. It is not turning on at all. I had a the entire fuel system replaced about 2 and a half months ago with a double pumper and hot wire. I tried to Crank the car today after letting it Sit for a month now the fuel pump won't turn on. The fp/inj fuse is good. Both 20a fuses under the hood are good and both relays by the tank are getting a good ground and input but the input is the only signal I am seeing. I'm not sure what else to check or where to go from here if someone could please help I'd really appreciate it.
