i think its the ecm,theres no power at the green/white for two seconds,i jumped a wire directly from the battery to the relay and the pumped turned on,also the fuse for te ecm is good,i did turn the key onto the on position and checked a couple wires going into the ecm and some had power (forgot colors though)Also i remember before the car started with problems,i was charging the battery with everything connected then when it charged i went to crank and the problem started,could that of been the problem?rodman99999 said:YUP- That's correct. As long as the engine is being cranked, or is running- he should have voltage at the green/white wire, as he will have C3I reference pulses. The ECM fires all six injectors together until it gets signals from the cam/crank sensors, then goes sequencial. Just turning it to "on" SHOULD give 2 seconds of power at that wire. If he doesn't have that, or any codes when doing the ALDL test, all the voltages/grounds/fuse/link are OK, and nothing's grounded that shouldn't be- looks like time for a new ECM.
yup i jumped the ses pins and dint get any code at all,is there any diagram for the pinout on the ecm? i really don know which the wires by there pin :tongue:rodman99999 said:Make certain your fusible link is good by checking for 12V at the orange wire(440a/main power) going to c16 on the ECM. check for good grounds at ECM a12, d10, d1. That'll at least tell you if the ECM SHOULD be working. Did you say you jumpered ALDL terms. A & B(ignition "on") and didnt get any flashes on the S.E.S light(should flash "12")? If it didn't- Did you check the ECM fuse? By the way: someone stated in here that the green/white wire only gets power for two seconds. That waire will ony get power for 2 seconds IF the car doesn't start. If the ECM gets the correct pulses from the ignition module, its internal fuel pump relay keeps that wire hot. That's what keeps the external(fender-mounted) fuel pump relay triggered.![]()
japSW20 said:ok checked the orange wire,it has power and so does a purple one a couple more,im guessing the ecm is shotthe car does have spark and fuel.im to the point where im going to load it on my trailer and take it to someone,on the side note anyone in central florida wanna take on the task??
i jumped a cable straight to the relay,i never checked the wire but i figured theres no point since there is no power coming out of the ecm to trigger the relay,i PMed a few people on her that had ECU's for sale.and for those interested you could see pics of the car in the members rides section under not your average t-typeSam Colalillo said:What I am confused the car has spark and FUEL now. You know you have good connections at the fuel pump relay (the groungd and power wires are fine), because you jumpered the green wire and the fuel pump turned on. I never really understood if you bridged power to this wire at the ecm connector or, if you put power to the relay.
I just wanted you to make sure the green wire going to your ECM was not shorted out. Did you ever circuit test this wire? If you jumpered 12 volts to the green wire at the location where it plugs into the ECM I am going to say that wire is not shorted out if your fuel pump turned on.
Next find out how much a remanufactured ECM costs for you car, I think this is what I would do if I were in your shoes.
