Fuel Pump Question for Alky
Chrisk
TurboTransAm.com
Im about to install Razors kick ass Alky System. However I dont have a walbro intank fuel pump. My setup is the stock In-Tank Pump and a External Bosch In-Line Pump. Is this sufficient to run alky?
Chris
If your O2's stay high in the upper 700's.. you'll be fine.
Altho a 340 in the tank, and getting rid of the external is what I would do.
Its only a Sat afternoon to swap the pump out.. once you start.. before ya know it.. you'll be done. And remove the pulsator.
Glad you likes :)
Thanks for the info razor.
Are there any step by step guides on how to drop the tank on a TTA??
Chris
http://www.89tta.com/fuelpump.htm
There are a lot of links in the "Faq's" post in the TTA section. Its a sticky.. just read through.
Dont disconnect the brake lines.. only unbolt them so the rear can come down. And get some 5 ton jack stands so the azz end of the car gets really high.. or use a lift.
Thats pretty much it.
