Under light to medium load it remained virtually unchanged....maybe 45psi from 40 at idle tops...the car has no crazy cam in it, I believe it is stock. The car makes about 14-15" of vacuum at idle if I recall....
The fuel pressure only really responds with boost, and it does seem relatively linear.
The regulator is a Kenne Bell billet unit, and seems to be in ok shape. Intersting point though- the line that goes to it has a zip tie on it, and what looks like maybe a little sealant of some sort....maybe the previous owner has problems with it popping off or leaking? It seems to seal up okay now...
I will more closely document the fuel psi at line on/line off condiitions, but I believe these numbers are correct.
Again, nothing else was changed- why would this problem surface now? If anything, I would assume I have more than enough fuel, not a shortage.
