THE WRAITH
- Apr 23, 2008
Ok, on my 86 GN my current fuel set up is an aeromotive 1001 that "Y"s at gas tank and has 2 #8 lines running to the "Stock" fuel rail.. I plumbed both ends of the fuel rail with #8 to each side. I have a stock location regulator with a #6 return line. I have been debating with a friend of mine who I admit knows more than I do about the setups on turbo cars... The debate is that the lines feeding the "stock" rail creates a problem that will lean out a cyclinder. That I need to put champion fuel rails with the regulator in the back or drop off and cap the fuel line on the passenger side. I can see where the champion fuel rail with the regulator in the back would be more balanced and effecient, but i dont see a problem with my current set up. Just curious to see what you other guys have to say about it and where the best place is to get the champion fuel rails (price) if I so decide to go that way. Thanks in advance for the imput.
