Fuel Rail & Regulator converted to AN fittings & Chrome Rear Diff. Cover
V6 Beast
Under Pressure
I have a stock fuel rail that has a -10 AN fitting welded onto feed side and a Accufab Fuel pressure Regulator that has a -6 welded on for return. Regulator is less than a year old. Setup worked great to 9.68@138. Pics if needed. $150 Shipped in lower 48.
Rear Differential Cover that is Polished or Chrome. Not sure. It is Shiny. Has a drain plug built in. Includes hex head bolts. $45 Shipped. Pics available.
I would like pics of the fuel rail please. Thanks!
v6 beast how did you do your lines coming out of the tank with the an fitings? i am looking to do something simular with mine and was wandering if you welded an fiting on the sender as well.
