TurboTnZ06
Go on red!
- May 7, 2002
Stock rail customized with AN screw/bolt-on -8 feed -6 return with Turbofabricator custom adapter. Both adapters can be undone to go back to stock. Comes with extra 5/8 dowty seal. I'll reinstall the shrader valve and stock rail cap too. $100 shipped
Sold - AEM UEGO wideband gauge and module plug n play, no calibration needed, comes with an extra used Bosch sensor that was working fine. It is powerlogger compatible. You'll need a bung welded in the downpipe. $135 shipped
Autometer Phantom 2 1/16 gauges:
Sold - Electric 0-100psi 90 sweep Oil Pressure gauge w/ threaded sender $45 shipped
Sold - Electric 0-100 psi 270 sweep Fuel pressure gauge, sender, metco rail adapter and wiring $125 shipped
Manual 0-100 psi 270 sweep Oil pressure with line and fitting to gauge $35 shipped
Sold - Manual 30inVac/30psi Boost w/ plastic vac line $45 shipped
TT 5.6 chip for 80# injectors $30 shipped.
SOLD - 3 inch bolt on high flow cat for stock 4 bolt flange. $50 plus shipping.
LS7 Maf sensor $30 shipped.
Feel free to make offers- this stuff has to go!
