Fuel rails, Water outlet and EGR block off plate
Mike E
Mr. Badwrench
I took a break from body and chassis dismantling on my T-type today and made some go fast parts instead.
A set of -8 fuel rails with mounts. The mounts took longer to machine than the rails did. I also whipped out a quick EGR delete plate and a new water outlet to replace the pitted stock steel piece.
The cylinder pieces are "mock up injectors" to help position the rails correctly when making mounts.
