Fuel sender connector burnt ?
HUENEMEGN
I’ve been having some fuel sender connector issues in when the bulk head connector power pin will burn out (1st picture). This one just happen last week .
I fix this issue 4 years ago but what burned out last time was the in-tank fuel pump to the bulk head connector (2nd picture) .
Ive replace the Racetronix bulk head connector twice now (3rd Picture). I just ordered a new one. But these have a weather proof connector and I’m wondering if the pin-outs are correct in my set up? I do drive the car about 600miles a year . But I hadn’t drove the car in about 3 months now. I’ve just been turning it on in my garage but last week it wouldnt fire up . I realized I had no fuel pressure . Tried priming the pump via connector behind the alternator and still no pressure . Took the pump out to bench test it , it works . Then I saw the burnt out connector .
Do I have a short somewhere. Any help would be appreciated.
My fuel pump is a DW400 .
I do have a newer Hotwire kit
All the positive current going through 1 pin?
Racetronix makes a “HD” bulkhead kit that sends the positive power through 2 pins that’s what you want.
2 pins for power
1 for ground
1 for fuel level
Then a nut & bolt bulkhead ground drilled through the header.
Use the HD version hot wire kit to the alternator
And use a 10ga copper strand ground wire from rear of car to the battery
This is an HD kit. Red & blue feed power. Grounds are black, note the nut & bolt ground. Purple is fuel level. They sell HD kit pieces for a few different pump connectors including tyco style.
