Squid4life
- Jul 5, 2004
Been out of Buicks for about 5 years so it kind of feels like I am having to relearn a lot as things have changed. I finally picked up a GN to build, and will be putting my Stage 2 engine in it later on. For now I will be running a 109 setup on alky and high boost, and have 120 or 160 pb/hr injectors on the shelf, but I am building the fuel system now to support the Stage 2 later, which should be 900-1100 capable with the right turbo. Plans later to also move to Holley EFI. I know it is overkill most likely, but I would like to get some more experience with Holley EFI tuning as part of my business supports that.
I know there are a few options for dual in-tanks from Racetronix, who has always been awesome. I am trying to decide between the Racetronix (Racetronix GEN2 "Double Pumper" Turbo Buick E100 Dual In-Tank Pump System 725LPH EQ) with AN -8 feed & return, or just go with RobbMc pick up and go external pump/ filters. I can get pretty good deals on Aeromotive, MagnaFuel, Holley, etc. I really didn't want to sump the tank mainly due to trying to keep it semi "low key" sleeper-ish.
Any thoughts?
Also need to look into converter/turbo combos, since some of the data and what's available has changed quite a bit...
Any thoughts?
