Fuel Type / Boost
Paul Clark
I've been using good old rubbing alcohol (70%) from WalMart.
Any rough guess as to how much I could raise the boost by using meth.
instead?
Maybe a better question would be what performance gain did you get when switching to meth?
Did the exact same thing just recently. I gained 2 lbs more boost with no knock. Just be sure to use some alcohol lube like Klotz uplon, or Redline alcohol lube.
2 more lbs. of boost would be fun.
Just to clarify - do you need the lube with the PAC kit?
And if so, where do you get it?
paul
If you have Razors PAC, you dont need the lube :) and i too picked up about a lil bit going from denatured to meth
