dwall
- May 25, 2001
The frame is almost ready! Its time to get replacement lines for my GN rebuild. The old lines are kinked and gnarely. We have a complete vacuum brake set up from an 83 Regal Sport Coupe so we have the pedal, booster etc. My questions:
Any help out there would be appreciated before I put more on the credit card? Thanks in advance.
Bob
- The fuel lines at Outaline Tubes show two 3/8" feeds and two 1/4" return lines - I believe the original is only one return line - what gives?
- Various vendors have the standard (PMaster) brake lines (& stainless) 7 pcs. I assume I should use this set even tho' I am going to Vac brakes - correct?
- The old proportioning valves are not brass and look terrible so ...... is this the correct replacement valve on fleabay? Would it have the right fitting sizes etc.?
Bob
