Ok I have been trying to fix a fuel issue that I have had for about a month. My fuel pressure will drop over the course of driving. If I start out with good fuel pressure (around 40psi line off) I can drive the car a couple of miles and check it and it will be down to around 36psi line off, and it has gone down to as low as 26psi. So I started by taking off the reg. and cleaning it and putting back on. It starts over back at 40, then drops with time, so I replaced it but it did nothing.
Here is what I have done.
Replaced regulator
Cleaned injectors
New Racetronix Hotwire
New fuel Pump (Walbro 340)
Still does it every time. I am getting kind of frustrated.
Any suggestion would be greatly appreciated!
Replaced regulator
Cleaned injectors
