Red Regal T
Senior Member
- May 24, 2001
I have a set and the packaging was damaged. No problem with gaskets. Sell for $75 shipped.
New 86-87 Tr Gasket Sets
Complete 86-87 Tr Gasket Sets
No need to suffer sticker shock when you price gaskets for your turbo Regal. These kits are top quality, NEW IN THE BOX, most gaskets in the kit are made in USA and others made in Canada and the kit contains the following gaskets.......
2 COMPOSITE TYPE HEAD GASKETS
1 CORK OIL PAN GASKET
2 CORK VALVE COVER GASKETS
1 NEOPRENE FRONT COVER SEAL
1 NEOPRENE REAR MAIN SEAL SET
1 O-RING FOR WATER OUTLET
6 VALVE STEM SEALS
7 FUEL INJECTOR O-RINGS
1 TIMING COVER GASKET
1 WATER PUMP GASKET
2 EXHAUST MANIFOLD GASKETS
1 OIL PICKUP SCREEN TO BLOCK GASKET
1 THROTTLE BODY TO PLENUM GASKET
1 UPPER PLENUM TO INTAKE MANIFOLD GASKET
1 VACUUM BLOCK GASKET
1 TURBO OIL RETURN GASKET
1 OIL PUMP GASKET
1 CAM SENSOR DRIVE O-RING
1 DRAIN PLUG NYLON WASHER
Don't forget, head gaskets, neoprene front and rear gaskets ARE included.
6 VALVE STEM SEALS
1 WATER PUMP GASKET
1 OIL PUMP GASKET
