I have a few questions about my new setup. I was running a Translator Plus, with the 3.5 inch maf and an Extender chip.
Now I am running an Extender chip for the GEN 2, a translator plus gen 2 and a powerlogger.
When cruising, anything close to 1/4 throttle and the 02's instantly shoot to 854mv. Block learn is at 114 cruising and I took out about 5% up to 3200rpm on the low load setting. Looking back at the instructions I noticed the "Main" setting can take away or add fuel across the whole spectrum (as opposed to adjusting fuel pressure) but I have not done that yet.
Is the block learn good to use at cruising as well as idle?
Are the Gen 2 chips set up super fat?
If I use a wideband setup with the Translator can it be used for fueiling across the board or just wide open throttle?
Thanks!
Thanks!
