RabidHamsterFab
- Apr 20, 2004
this is the best part of the forum I can think of too ask this question about my project and solidify better my plans and ideas
I've got a 86 delta88 with a fwd 3.8 (pre 3800) ... I am on the verge of doing a pretty basic turbo add on to the motor ... while the rwd buick and fwd buick motors are very close ... it's the differences I have a small problem with.
first off I'm using a small turbo (very mildly modded CT26) for a mild 300hp with very very quick spool . I'm going to be using a GN intake manifold and rail .. with an adjustable FPR... but aftermarket injectors .. Translator plus and aftermarket LT1 maf
myquestions are this...
- what injectors are the best option for only 300hp (without maxing right out)
- I have pedestal mounted rockers (not the normal shaft mounted, so I can go to SBC rockers) ... I plan on keeping the stock N/A cam. but going to aftermarket rockers to get the extra lift ....what are the largest rockers a 3.8 buick can run? I plan on 1.7 intake and 1.8 exhaust (stock cam specs are .250 lift intake, .255 exhaust)?
- finally the great chip question .... who would everyone recommend for a custom chip? I don't really want anything exotic beyond a "stage 1" GN chip but there are a couple other requirements in the chip involving the TC lockup I will need
thanks in advance... if you need any more info to help with advice... please don't hesitate to ask![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
