SignUp Now!at7we2 said:I installed a GT3255E on my hardtop GN (recently sold) and within a few weeks a friend of mine also installed one. we both had the same problems -unable to control boost and the stock turbo shield will *NOT* fit without removing the inboard side (opposite downpipe) of the shield. And you will have to bend the stock oil feed line so an aftermarket braided steel line is not a bad idea. I already had the braided line from John's performance on my car, but we had to bend the oil feed line on my buddy's car as well as use a few bucks worth of brass fittings from the hardware store.
I agree 100% about the fast spool, I had a re-stalled D5 in my car and I believe so did my friend's car. The GT3255 was wicked fast spooling, but we had hell of a time getting the boost under about 19 lbs. I wanted a fast spooling turbo that would work with pump gas and still be able to easily generate 20+ lbs at the track. I was not happy with the controllability of this turbo. The next time I'm in the market for a relatively small, streetable turbo I'll buy a 44 or a 49.
I'm not sure why no one else has posted this kind of experience with the 3255, but that's my experience with it.
Rob
Pronto said:Dan, which 44 and wheel are you running? I thought about the GT 3255 but I think I can live with alittle less bottom end and would like to keep pulling at the second half so that leaves the 49, 44 or 60. Pretty much think it will be a 44.
Grumpy said:110 MPH is not an 11.511s maybe harder than you think .. the 3255 does not pull like a 44 on the top end
I had one for a few weeks ... 44 went back on
they do spool faster but we run drag radials so we really dont need more bottom end
