GNVYUS 1
- Dec 15, 2002
Well it's been in the works since 2021 and it's done. I had maxed out the TA49 with my new combo at 520hp and only 19psi so I wanted to make a big change, not just the turbo but the mounting and control of it too.
This isn't for those looking for easy or cheap, it's even more $$ than I thought to do all this and I gave it a big #. If you think $6k, more if a shop does the labor. I'm a GN lifer here so it's fun for me but damn it's a lot of $$ to move into the 2020s gated turbo community.
Turbo = Garrett G30-770 = 58/55 in PTE size
V Band .83 exhaust housing
Poston header modified for wastegate
Turbosmart 50mm wastegate with custom dump tube
Controlled by ECU-GN boost solenoid
GN1 3.5"DP modified using Garrett DP adapter
Custom turbo oil return to stock block location
Water feed fittings off intake and returned to water pump
Custom length oil feedline off oil filter adapter
Coatings by LOKO here in IL
Work done at Blackdog Speed here in Lincolnshire IL by techs Gordon and Jeff.
I think of ways to smoke Gs and they make it happen.
Steve D will tune it up when he's back so he'll have more details soon on what is actually happening vs other turbos we run our those of us rocking the TA49.
The biggest challenge was the turbo oil return. I was going to run the T-40 Turbosmart Oil Pressure Regulator but the oil return for that alone was a mess so I ditched that before spending tons of custom hours on it. Then we realized the turbo oil return in general is too tight to get a wrench on for the fittings so....
We used the Garrett G series Aluminum oil turbo flange, welded a tube onto that and a -12an onto the end and cleared the turbo and v band flange. Then run a 90 degree -12an braided back to the block.
To think the header mod for the wastegate and pulling all the headers for coating was easier.
I'll come back after it's retuned and dynod at the same 19psi and 18 degrees like the TA49 to show what 1990s vs 2020s turbo tech has evolved too.
