Gasket recommendations
highboostgn
Im about to swap my stock intake with a champion intake and swap my heads out with some ported ones. The block hasn't had any machine work done to it. What head gaskets and what intake gaskets would work best?
Only found Someone asking about stock 109 block and aluminum heads , 6 pages of people talking about blowing them,cars for sale etc
Use the factory style pan intake gasket unless you plug your PCV valve. Using the Felpro 1200 intake gaskets will require modifying your PCV valve or it'll suck oil and cause engine smoking.
