borderline
- Apr 15, 2011
Hi all! I'm building a rear end (my first one) and would like some opinions on the pattern I am getting. This is a 7.5" 10 bolt, I know they are weak I got the housing, limited slip carrier and gear set for free out of a parts car that was given to me. The gear set is a Richmond, and their website shows a backlash tolerance of 0.008" + 0.004" -0, backlash right now is at 0.011". The pinion currently has a 0.040" shim in it. Would you run with this pattern? If not should I add more or take out some shim? Thanks!
