larrym
West Coast Newfy
- Jul 17, 2007
So I have been playing with the Gen 2 and really like the features and tune ability it gives.
I use the Extender G chip and have been adjusting the timing to get peak performance and drive ability.
I have the timing down in the lower rpms to try and eliminate some transitional knock I can here it knock if I mash throttle from a dead stop or a roll at about 30 to 40 mph. I have the alky coming on at 1 PSI to try and eliminate it but the only thing that curbs it is less timing 17 degrees until I get to about 3000 rpm then I ramp it up to 22 degrees.
The turbo spools really quick so the early alky spray does not seem to affect performance.
My old chip was burned for 25 and 23 degrees and I didn't see much if any transitional knock.
Am I approaching this properly?
I'm not too concerned about the lower timing down low should help me brake boost at the track, but when I use the lean cruise on the hwy it prefers more timing.
