JSD69Vette
- Oct 15, 2006
I'm going to try this again, this time I specified that it's the Gen 2 that I need help tuning with and I hope that drew guru's to the thread. Anyway:
I'm thinking that my tuning is off(messed up) using the GenII system.
Currently blm's are within range at idle (136), cruse condition (125 - 129) and WOT passes showed approximately 840 o2 and .5 knock (worst reading a couple different times) at anywhere b/t 23mph to 55mph.
Here's the thing:
to get those readings my GenII settings are as follows:
Mainscale: +25.5%
Lo load: 800rpm; -28%, 1200rpm; -30,5%, 1600rpm; -29.5%, 2200rpm; -28% and 2800rpm; -23.5%.
mid load: 800rpm; -28%, 1200rpm; -30%, 1600rpm; -28.5%, 2200rpm; -26.5%, 2800rpm; -21.5% and 3400rpm; -7%
no high load changes made.
Also, WOT spark is set at 18* across the rpm band. All other reading are within range
This plus on one side and minus on the other seems wrong to me.
In an initial reply from a member long ago lost that I just found, I was told to use mainscale to get cruise blm's close to 128 and then stop the car and place in park and tweak idle blm using lo load page if needed(b/t 800 and 1200 rpms). Once that is set use high load watching o2 millivolts and knock to set WOT fuel delivery. This assumed all GenII settings started at 0%.
Given my settings should I zero everything out and start over? If yes, is the above advise the way to correctly tune this thing? I'd like to get out to a local track this weekend but don't want to go there with this setup if I'm way off.
One last thing, this advise also said to set my monitor to read rpm and load in order to know what load points the high range needs to be tweaked in. It said that the GenII will calculate load during acceleration. I'm not sure how to do this, does the scanmaster do this?
Any help would be greatly appreciated.
__________________
Here's the thing:
Mainscale: +25.5%
__________________
