ski_dwn_it
- May 3, 2005
Got a question for you all.
Have been running the Gen7 now for about 1 year. Got the car pretty well dialed in, but many of the guys I race with at the track are going to MSD digital 7 boxes, the one that you can retard timing at various stages throughout the run.
For instance, on the launch you can pull 8* to keep your car from spinning, then on each gear change subsequent changes can be made.
DO not be confused when I say retard, with their box you set a max timing say 40*, then if you want 36* through the run you retard 4* for an example.
So if you want only 28* off the line you pull 12* from 800rpm - 4500rpm, then ramp back in the timing to full.
Question is, can any of this be done with our gen7 units? I do not think there is anything to differentiate gears in the program.........
I would imagine this would have been pretty easy for them to do - and not sure why its not included.....
