- Feb 18, 2006
Version 1.20 for the genII has been officially released. Some cool new features have been added. Wideband tracking can now be monitored on your powerlogger by in-putting one of the analog outputs to the PL I/O 4 or 5. Most will prolly use analog output 2 because 1 is being used for wot timing if you running a fullthrottle chip. TT chip users can use 1 or 2. Set analog output to wb correction in the genII configuration. Then set the input 4 or 5 (depending on which one your using) to correction factor in powerlogger configuration. You can then click on one of the graphs and change to correction factor.
Some other things added are tps enhancement, tps decay and off idle fuel. These can be used to help with off idle stumbles and drive-ability issues.
The loader program is in the new file as well and can be used to save all your settings to your computer. I recommend saving your settings so they can be uploaded to the genII after the software re-flash. A memory reset after the re-flash is also recommended. So save your setting.
ADS and XDF files are also available for use with Tuner Pro along with a new genII manual.
Feel free to post any related q's here.
Link to files. MAF Translator Gen II - version 1.20 software - DOWNLOAD HERE! - Full Throttle Speed Tech Support
