Geez, I couldn't even think of a catchy name for my thread title.  And sorry if this is in the wrong place.  My intent is serious.
I have a few random questions. To be clear, I'm not mechanically inclined and have much to learn. Talk to me in laymen terms. I try my best to read and get an education and apply some common sense, but somehow I get the feeling I'm asking dumb questions. Oh well, there's only one way to find out, so here goes:
Fuel Pressure Regulators: Yes I've read threads. I understand that if I replace mine, I need to set it to 43# off vac. Question is why 43#? Wouldn't that result in inadequate fuel pressure at anything above idle (under acceleration) once its back on vac?
Also - and this is to the contrary of my above statement - , if you set it 43#, and I only have 42# injectors, how does/would the pressure exceed the injectors ability of 42#? I suspect that even though I have 42# injectors, that means they are capable of processing at "X #s " while under throttle and boost?
On the subject of the FPR, I have an XP Plus Fuel Pump and Feeder. I'm certainly assuming that's adequate so that when I change the FPR, I can have it set properly (which I know is going to be the 43# mentioned above). But in hindsight, I don't know what the capability of the fuel pump is. Anyone familiar with these?
Valve Springs - My car has stock springs. I believe these were about 80#? The only mods I've done are in my signature. How do I know what springs are acceptable that won't cause any damage? Do I get 80# springs? 100#? I know (think?) lots of guys go with the Comp Cam 980s, but aren't these a rate of 308 #/? What am I missing here?
Wastegate Actuator - Again, I have the original stock one, so its the solid rod. I'm only pushing about 11# of boost under throttle (and I have the separate boost gauge installed so assume its accurate), and therefore on the low side. I'd like to see about 16-17#s for now, which I think is reasonable/safe for my current set up. Maybe its included with the directions when the part shows up, but where do I start with my adjustment on the rod? None at all - and then test drive and make adjustments in small increments? 1/8"? 1/4"? (Its not my exhaust holding back boost, as I've, ahem, temporarily removed the cat for testing purposes).
Go easy, fellas. Thanks.
