Mods are:
Headers
CAI
42lb inj
HP fuel pump
TT street chip for 93
Adj fuel regulator
Aftermarket boost guage
ScanMaster 2.1
A wise man will listen carefully to Razor's experience
This statement is confusing! You say he has alot of room with his injectors but in the same sentance you say you don't know his goals! so how do you know if the injectors would be good? My info was 100% commonsense not a shot in the dark! Yeah, get the Alky kit then you WILL have to get the TT Alky chip to match! (commonsense!) As far as injectors go, Example: I have a buddy that has 42lb injectors, Razors Alky kit and a TA-49 turbo running 27lbs boost and those injectors are borderline at that boost! I personally had a TE-44 with 60lb injectors and they worked awsome! then I switched to the TE-45a and I still had alot of room left with the 60lb injectors @ 28lbs of boost. So, Since we don't know his goals and like most of us we just don't stop at one point I think the injectors should be up-graded, it won't hurt gas milage, it won't hurt the set-up, it will only provide more room for protection. you do what you want, it's your engine!Your injectors have a lot of room remaining....We still don't know your goals or intentions, so we're all just shooting in the dark.
I guess I don't have any plans in particular. I would just like to have a pretty fast street car. Don't plan on drag racing. I am already starting to see that I will need slicks/drag radials soon. Once I see around 17lbs of boost, I start to go sideways:biggrin:
